Misfire code Help
Old Apr 2, 2020 | 11:10 PM
Frank Leal's Avatar
Default Misfire code Help
My 2007 Chevy Tahoe 5.3L has check engine light on. Pulled codes and getting P0304 (cylinder 4 misfire). Swapped coils from cylinder 2 to cylinder 4. Swapped wires from cylinder 4 to cylinder 2. both of those produced no changes. Still misfiring on 4. I also did a compression test and am posting the results below. Below is some data that I pulled from the OBD port also. Any ideas? My thought is to check the injector for blockage -any thoughts? from the data collected it appears to be misfiring on more than just cylinder 4 but not throwing codes for the other cylinders. Should I replace the spark plugs they have been in there for a while. current spark plugs have been in there for 30,000 miles. would appreciate some help. just some background: back in 2017 had both cylinder heads rebuilt as I was getting misfiring on cylinder 3 and mechanic tested compression and determined some exhaust valves were leaking/burnt. It ran fine since then until recently.
back of engine
8- 195 psi 7- 195 psi (COMPRESSION TEST RESULTS)
6- 200 psi 5- 195 psi
4- 215 psi 3- 190 psi
2- 195 psi 1- 180 psi
front of engine
Old Apr 2, 2020 | 11:34 PM
Modern spark plugs should last much much longer than 30k miles.
Your test results seem fine to me.
#4 is the worst. It probably crossed the threshold to throw a code, but it looks like #7 is not far behind.
You could try swapping injectors.
Old Apr 4, 2020 | 1:08 PM
Frank Leal's Avatar
thanks for the advise. I'm going to swap injectors around today. I hope that's it and not a burnt valve issue.
Old Apr 4, 2020 | 10:29 PM
Frank Leal's Avatar
actually cylinder 4 was not misfiring-it had a while back but not recently. I removed both banks of injectors and cleaned them with electronic parts cleaner while applying 12volts to the injectors. . cylinder 7 was the one misfiring. and after swapping injectors in other cylinder locations, and placing the injectors back on engine it continued misfiring. I swapped the spark plug form cylinder 7 with cylinder 1 and cylinder 1 began misfiring where it had not before. I"ll be replacing all plugs. FYI
Old Aug 20, 2024 | 8:21 PM
pit17's Avatar
Did this fix the issue?
drew1
Aug 28, 2014 9:28 PM
unkindshadow35
Feb 2, 2013 10:50 PM
a_kraker99
Nov 6, 2012 9:25 AM
TahoeMatt
11
Feb 6, 2012 7:15 PM
adambraap
Jan 28, 2007 9:58 PM
