Misfire Issues - 2007 Tahoe 5.3
Old Jan 9, 2016 | 7:25 PM
Plimbob's Avatar
Default Misfire Issues - 2007 Tahoe 5.3
I have a 2007 Tahoe 5.3 that after driving on the highway for 2-3 hours the engine will develop a misfire. The plugs and wires have been changes approx 15k ago. I run Autolite Iridium plugs.
It happens in random cylinders, over a two month period it has shown up in cyl 1, 6,7 and 5 and when the plug is pulled it isn't fouled. I replace the plug and it stops the misfire and runs fine. I am leaning toward the following:
1. Fuel problem - I try to stay away from Ethanol but sometimes that is all that's available. I travel in the midwest.
2. Fuel injector sticking
3. Coil - this is probably the lest of the probable
Any input would be greatly appreciated.
Old Jan 9, 2016 | 9:50 PM
Try using the OEM AC Delco spark plugs and see if that doesn't help.
Old Jan 10, 2016 | 11:13 AM
cleveland63b's Avatar
yea get that autolite junk out of there
Old Jan 12, 2016 | 5:57 PM
magician's Avatar
X3 on the plugs. OEM AC Delco. For some reason those fancy plugs don't run long or well in this set up?
