Multiple electrical problens on a 2003 Chevy Suburban
Old Nov 19, 2017 | 9:22 AM
jlsteinauer6's Avatar
Question Multiple electrical problens on a 2003 Chevy Suburban
I'm having numerous electrical problems with my suburban. If I turn my right turn indicator on at night it causes the brights to turn on. My front passenger and rear driver side windows wouldnt roll up and the electric mirrors had stopped working from the driver door panel last year and still could make the windows roll up from their seperate doors then a little over a week ago the driver window suddenly stopped working so I very carefully and thoroughly cleaned the circuit boards in the driver door control pad and cured the problems with the passenger and rear driver side windows and the passenger aide mirror. Still nothing with the driver window and mirror. I started looking at fuses and cleaned all the ones on the fuse panel on the driver side. Got my rearview mirrors compass and temp display to start working again. I also have a problem with the ABS light suddenly going off and on without reason. And the 4 wheel drive will switch itself into 4 high, 4low, or neutral with out being switched by me. Then i will get a message to service the 4wd. I would appreciate it if anyone can give me an exact diagram and what each does for my fuse panels and the wiring schematics I have looked up several and unfortunately it always has info for another vehicle so i cant figure out exactly which ones i need to check.
