Is my engine toast?
Old Feb 9, 2016 | 10:53 PM
4x4van's Avatar
Default Is my engine toast?
196K miles, oil level OK, but oil pressure is about 20 while driving, drops to 0 at idle, beeping/low oil pressure warning in DIC.
Time for a new engine, or am I missing something easier and cheaper?
Old Feb 9, 2016 | 11:10 PM
year, engine?
could be a bad oil pressure sender or clogged sender screen...hard to say without knowing the build?
any engine knock or lifter tick noises?
Old Feb 9, 2016 | 11:24 PM
4x4van's Avatar
2006 LT 4WD, 5.3 engine. Valve ticking noise quite obvious.
Old Feb 10, 2016 | 2:15 AM
Scotiapilot's Avatar
toast
Old Feb 10, 2016 | 1:23 PM
cleveland63b's Avatar
ticking all the time or when the pressure drops? i'd think it would be worth getting a mechanical oil pressure gauge on it and verifying, depending how much you've drove it that way you may not have to condemn the entire engine
Old Feb 10, 2016 | 6:54 PM
4x4van's Avatar
Ticking all the time now, although it quiets down a bit if I drive it. It's my wife's truck so I don't know what the pressure was reading prior to this, but it's never had the warning/beeping before. Parked now, will try to drop the pan this weekend and take a look; oil pump pickup, o-ring,...clogged filter perhaps?
Old Feb 11, 2016 | 4:11 PM
Been there, done that. 1 says its toast
