Mysterious rough idle
Old Yesterday | 12:32 AM
Busutil's Avatar
Default Mysterious rough idle
Hello,
I have a 2014 Chevy Suburban LTZ (5.3L) with 148,000 miles. I do all my own maintenance and keep her in as good of shape as I can. Recently she started to have a slightly rough idle. (Her first issue besides a cracked dashboard) Initially it was intermittent, sometimes idling perfectly smooth and sometimes the idle was noted to get a little low causing a slight shake. I could barely see the Rpm needle moving but it was noticeable. I figured it was possibly carbon build up or possibly dirty fuel injectors. I tried a concentrate fuel injector cleaner but there was no apparent change. I then did the following:
  • Using an OBD2 reader I see a P0300 Random Misfire (No Check Engine Light)
  • Short Term Fuel Trim on both Bank 1 & Bank 2 is approximately 0% to -2%
  • Long Term Fuel Trim on both Bank 1 & Bank 2 is approximately -17% to -20% (Rich)
  • Idle rpm varies from ~620 to 550
  • Engine running fuel pressure = ~42/43 psi
  • Replaced 8 new spark plugs (No change)
  • Replaced 8 new spark plug wires (No change)
  • Replaced 8 new ignition coils (No change)
  • Cleaned MAF sensor (No change)
  • Mass air flow rate from MAF sensor = 0.706 lb/min (Should ideally read around (5.3 grams per second at idle)
  • Converting 0.706 lb/min to grams per second (x453.6 / 60) results in approximately 5.34 g/s.
  • Unplugged MAF sensor to see if there was a change (Ran worse and threw MAF codes)
By now the slightly rough idle is getting worse, sometimes stumbling and sounding like it wants to die before the ECU catches it. I then did the following:
  • Removed and cleaned the throttle body.
  • Noted it as somewhat dirty, dirtier on the back side of the butterfly.
  • Noted the intake appears slightly wet.
  • Re-installed and did the idle re-learn procedure (No change)
  • P0300 Random Misfire remains (No Check Engine Light)
By now the slightly rough idle is causing the engine to randomly die when slowing down to a stop (This happened twice)
I then
  • Replaced 8 new fuel injectors
  • Replaced the EVAP Purge valve
  • Noted reduction on idle stumbling below 500 rpm, no engine shutting off noted while slowing down however slightly rough idle remains
I then
  • Dropped the fuel tank and replaced the fuel pump / fuel pressure regulator assembly
  • Fuel tank appeared very clean inside
  • Used compressed air to blow out all the fuel and vent lines, no debris/charcoal came out of the lines (Only a small amount of fuel)
  • Reinstalled and drove ~5 miles round trip to the gas station to fill up.
  • Started right up, no leaks, fuel gauge works, no issues filling.
  • Idle still feels slightly rough.
My next steps will be to inspect, clean or replace the O2 sensors.
What else am I missing? Why is this engine running rich on both fuel banks?
Other maintenance I have recently done:
  • New brake pads and rotors
  • New tires
  • New front and rear air suspension
  • New serpentine belt
  • New battery
  • New wipers
Thank you for any help or thoughts.
Old Yesterday | 8:24 AM
a55bruce's Avatar
Check the Ethanol percentage in the OBD2 readings. If it's way off from what you're using this may cause the rough idle, and rich fuel trim.
nvious62
Sep 2, 2025 1:35 PM
Voxy
2007 - 2013 (GMT900)
Jan 2, 2023 12:34 PM
Cole Bixler
Apr 20, 2017 7:43 PM
pjking
Aug 6, 2016 12:28 AM
madman76
Jan 28, 2011 8:30 AM
