NAV
Old Mar 1, 2007 | 1:13 AM
07LTZGREYSTONE's Avatar
Default NAV
My nav keeps going in and out of signal every five minutes religously for the past 2 weeks..Anyone else have this problem or know a fix??
THANKS
Old Mar 1, 2007 | 10:10 AM
konasmrz's Avatar
Default RE: NAV
Make sure you did not squash the GPS wire behind the radio when you installed it. You need to be sure the cable is positioned in the slot under the head and does not pile up behind when you are screwing the NAV back down. It is easy to short the cable this way (I know - I did it), Pull the head and if the foam on the wire is flattened out that's likely your problem.
shoveldead
Jul 11, 2015 8:42 AM
cjasonsmith
Feb 21, 2009 10:50 PM
dac44444
Feb 15, 2009 4:28 PM
cmonteiro1
Jan 8, 2009 9:32 PM
Shawn2007TahoeLTZ
Nov 4, 2007 11:36 AM
