nav and battery
Old Jun 21, 2008 | 7:56 PM
bair1218's Avatar
Default nav and battery
ok i got the delphi nav upgrade for my 06 tahoe and a few things bother me. i hoping someone could help. ok so the nav makes a slight speaker pop sound if you start the truck when the splash screen is displayed on the nav, but if you hurry and start it b4 the screen comes up no pop??? second is it sounds allmost like theres a fan running on the back of the nave even when its off, is this normal?
and i see everyone has a prob with there factory batteries and im no exception with 3 trips to the dealer and 30,000 miles it dies constantly dealer says its fine every time????
also sorry its a 06 z71 tahoe
Old Jun 22, 2008 | 9:24 PM
Default RE: nav and battery
Welcome to the Tahoe forum. If the 06 version is like the 07+ nav, then the fan noise you are hearing is the map DVD spinning up so the system doesn't take as long to respond when you access it. Can't help with the speaker pop.
Old Jun 24, 2008 | 8:42 PM
BMoTahoe's Avatar
The way to help eliminate the drain is to remove the nav disc when you shut down.
Old Jun 25, 2008 | 3:57 PM
bair1218's Avatar
but even if ileavethe disc out it it still makesthe noise it does it when the slash screen is up
Old Jun 25, 2008 | 10:10 PM
If I remember correctly, there's also a hard drive that spins up that you can hear.
Old Jun 25, 2008 | 10:15 PM
I don't have the Nav but I do have the entertainment packageand mine has cooling fans that run anytine the radio is on for more then a minute or so...they are very audable with the sound turned down or at a very very low level.
Igotasilveradonstuff
Dec 8, 2010 12:55 PM
cjasonsmith
Feb 21, 2009 10:50 PM
dac44444
Feb 15, 2009 4:28 PM
cmonteiro1
Jan 8, 2009 9:32 PM
Shawn2007TahoeLTZ
Nov 4, 2007 11:36 AM
