Nbs Tahoe and suburban alignment question
Old Dec 24, 2012 | 12:23 AM
blueinterceptor's Avatar
Default Nbs Tahoe and suburban alignment question
Is there a trick to getting a good alignment on a nbs Tahoe or suburban?
I installed the michelin ltx ms2 on a 2012 Tahoe and 2013 suburban. I had them aligned at 2 different shops and both times for both vehicles, the steering wheel does not sit straight. It needs to go over at least half an inch to the right.
Tires are 275 55r 20 on 5 spoke Chevy rim
Old Dec 24, 2012 | 9:30 AM
SWHouston's Avatar
Getting the steering wheel straight is something related directly to the guy who did the alignment. You need to take it back to them, or, find another Shop, who won't let an error like that get out the door.
Old Dec 24, 2012 | 12:39 PM
MDTAHOE's Avatar
Professional Mechanic
Find a competent alignment shop. Setting the steering wheel/ toe is the easiest angle to set on alignment. If they can not do that correctly how good os the rest of the alignment. Are you sure you are not turning the wheel crooked to compensate for a pull to the left. Let the wheel go does it sit straight but the truck goes left? You may have a tire pull or a bad caster adjustment. Switch the front tires side to side does any thing change?
Old Dec 24, 2012 | 8:00 PM
please tell me they are doing a 4 wheel alignment and not a 2 wheel alignment.
If you look at your alignment printout, it will show alignment numbers for the rear if they are doing a 4 wheel alignment.
Are the factory original plastic alignment knockouts still in the upper control arm eccentrics?
Old Dec 24, 2012 | 11:08 PM
they have done a four wheel alignment. all indicators including the toe are in the green. but the steering is always a little off. as is the sweet spot. it is very noticeable on the highway.
i have brought it to the dealer, they so far have been the best but its still off.
i have not switched the front tires. what does that do anyway? i really dont know.
Old Dec 24, 2012 | 11:17 PM
MDTAHOE's Avatar
Tahoe and Suburban have solid rear axles and are not 4 wheel alignment capable. No way anyone could do a "4 wheel alignment"
Old Dec 24, 2012 | 11:22 PM
If you do a 2 wheel alignment on any vehicle it aligns the front toe setting to a geometric centerline not the true thrust angle. A mistake that will cause off- center steering wheels if the thrust angle is out.
2 wheel alignments should never be done at any alignment shop.
You do a 4 wheel alignment to properly set the front toe to the rear thrust angle
Old Dec 24, 2012 | 11:35 PM
I just want to verify your concern. the vehicle drives straight but the steering wheel is off-center? There is no pull, correct?
When did the off-center conditons start? After the first alignment/tires?
Any lifts or blocks on the vehicle or is it stock?
Old Dec 25, 2012 | 12:43 AM
Stock vehicle
Vehicle goes straight but steering is off center
Condition occurred after installation of tires and first alignment
The one thing that seems common, is the shops machines seem to compare the new tires to the
Specs for the Alenza's. 275 55r 20's
Old Dec 25, 2012 | 8:48 AM
LTL4life's Avatar
I would agree that the alignment issue has to do with the person that did it. I adjusted the T-bars on my 2500 to get full level, i put on 265 tires that are not offered on a 2500 then i put on KMC enduro wheels with zero offset that are wider then the stockers and gave me a slightly wider track up front. I took it to the dealership for alignment. It tracks dead straight with the wheel perfectly centered. I'm not crazy about dealership labor rates but they do ALL the work on my burb.
