need differentail expert
Old Nov 23, 2012 | 12:30 PM
hunterjo's Avatar
Question need differentail expert
after my diff. came apart awhile back(this is on a 2001 suburban 1500 4x4) i rebuilt it with new ring & pinion all new bearings and seals.set it up like what i read now have a few problems. first problem i have slight whin from 60 to 40 mph on coast, now i have axle seal leaking rt. side and a vibration when i go over 68 mph. could i have bearing preload wrong or something else not right. need all the input i can get.
hunterjo
Old Nov 23, 2012 | 2:39 PM
kevinkpk's Avatar
Did you replace all gears with new?
Old Nov 23, 2012 | 5:41 PM
hunterjo's Avatar
yes ,everything but the carrier were replaced with oem replacment parts
Old Nov 23, 2012 | 8:52 PM
MDTAHOE's Avatar
Professional Mechanic
The whine you described sounds like a pinion bearing most likely from incorrect set up. Setting up a rear is not really a DIY repair if you want it to last. Most shops will not do internal rear work if that tells you something. Axles and seals yes but not anything else. It takes an experienced person with special tools to do it correctly.
Old Nov 24, 2012 | 4:26 AM
SWHouston's Avatar
Originally Posted by MDTAHOE
Setting up a rear is not really a DIY repair if you want it to last. It takes an experienced person with special tools to do it correctly.
I definitely agree with that !
Old Nov 24, 2012 | 7:28 AM
hunterjo's Avatar
i guess i do not know what PM is. if you tell me then i can go to the next step. Right now i am so far into this projest i can no longer turn back.
Old Nov 24, 2012 | 8:03 AM
kevinkpk's Avatar
PM is private message. Dealing with bearings, and gears requires mearsuring gear mesh clearances ect.
Old Nov 24, 2012 | 11:43 AM
SWHouston's Avatar
hunterjo,
Now you know what a PM is.
Many of the more experienced users on this and other forums, don't like to respond to a question thru PM, which would be helpful to the users and visitors to the Forum. If it would be helpful in PM, then why not say it in public.
Often times, newbies don't understand the terminology of the Forum or the Industry, but, don't let that get in your way to ask any clarification you wish. One of the rewards of dong this, is knowing we helped someone out. That means a lot to all of us.
Old Nov 24, 2012 | 2:42 PM
hunterjo's Avatar
my next question is how do i get a answer on a public thread. i did not consider these questions a private message. i still am a little confused on how things work on this site. any guidance would be helpful.
Old Nov 24, 2012 | 3:11 PM
kevinkpk's Avatar
Trying to answer questions that you have are too involved. You have a gear mesh/backlash issue (I assume since I cannot see it) and or bearing issue (suspect). If you don't have a manual for the differential, get one. You'll also need plasti-gauge for gear mesh clearance, and precision measuring devices, i.e. micrometers, feeler gauges. This is just the start. If you have alot of experience with gears, bearings, you should understand you need the spec's.
PM is private message, some don't do pm as in one of the posters tag line. this isn't directed to you, but in general as this is a bulletin board, and questions, with prospective answers should be public. I am not a moderator nor would I be.
