Need help with my 96 Suburban 2500
Old Oct 20, 2017 | 8:46 PM
Kalebwendt1's Avatar
Default Need help with my 96 Suburban 2500
Hello! First time posting on this site. I have a 1996 Suburban 2500 with tje 7.4l in it. Four wheel drive. Had an intermittent issue where it had to crank for 30 seconds to start, then ran fine. I put a new Crankshaft Position Sensor in it, and now it just cranks and wont start. Also has a new ignition control module and ignition coil. Not sure what else to do! Any help or advice would be appreciated!
Old Oct 21, 2017 | 7:55 AM
oilcanhenry's Avatar
It the vehicle showing any codes?
Old Oct 21, 2017 | 8:52 AM
Check the fuel pressure. You can also spray some fuel or starter fluid into the throttle body. If it runs for a few seconds then you need a fuel pump.
