Need help with a steering problem
Old Oct 16, 2006 | 1:43 PM
bosephus311's Avatar
Default Need help with a steering problem
My wifes Tahoe 4x4 is jerking to the left or right when turning at low speeds. I got her new tires and got an alignment and nothing worked so if you have any sugestions or info that would be great Thanks
Old Oct 16, 2006 | 3:14 PM
jasonw75's Avatar
Default RE: Need help with a steering problem
what year and tire/rim size??
Jason
Old Oct 16, 2006 | 4:38 PM
It is 1999 and has 16 in rims
Old Oct 16, 2006 | 5:23 PM
Dondobe's Avatar
Bosephus311, I had the same problem with my "99". (183,000 miles !!) It drove me crazy !! There is a sensor under the dash on the steering column. I can't remember the proper name for it, but mine was light gray in color and it raps around the steering column. Good Luck !! Dondobe
P.S. I found out it's called the EVO Sensor.
Old Oct 17, 2006 | 6:51 PM
ZX1100F1's Avatar
The sensor is the "Steering Wheel Position Sensor" also commonly referred to as the spool.
You will need to have this item replaced, it is a common problem in the 1997-2001 vehicles with Speed Sensitive Steering that utilize the Electronic Variable Orifice (EVO) type power assist.
bobbygrady
Aug 14, 2013 8:57 AM
w002mia
Jun 29, 2013 3:27 AM
w002mia
Mar 18, 2013 11:42 AM
cyberrkatz
Jan 31, 2011 8:54 AM
stinger_06
Aug 25, 2009 6:30 AM
