Tahoe & SuburbanThe power, space, and brutal towing ability make the Tahoe and its longer sibling, the Suburban, arguably the best full size SUV's on the market today.
Hey everyone, I'm Rick Baran. I'm a retired sailor who owns a 2000 Z71 Tahoe.
As the title states, my tachometer, speedometer, and odometer have stopped working. My transmission will shift into/out-of Park, Reverse, Neutral, and 3rd. My transfer-case appears to shift normally as well(I have the electric switches on the lower dash to the right of the steering column).
Once in a while(maybe 1 in 25 starts) EVERYTHING will work normally for a few hundred feet up to an entire day's driving(25-30 miles).
Anyways, I have been researching on our interweb, and decided to replace the two Speed-Sensors on the transfer-case. That had no effect whatsoever. I also disconnected the battery and checked ALL fuses with no change.
I read that the VSSB(?) was located behind the glove-compartment. I cannot locate it behind the passenger's glove-compartment. I don't have a wiring-diagram nor do I have a component-location diagram, so I'm having difficulty proceeding any further in troubleshooting.
Do any of you have any ideas as to how I should proceed? I've read several forum-posts discussing the possibility of a bad Ignition-Switch. I've also read about the VSSB, which I take it is a sub-computer and not the big clunky heat-sinked box on my driver-side inner-fender?
I've also considered finding a 6.5 diesel and a 4L80 transmission and replacing my 325k mile 5.7 gas/4L60. Anyone wish to weigh-in on that option?
