Need suspension upgrade advice: 99 Sub
Old Dec 20, 2007 | 1:58 PM
Gryphon's Avatar
Default Need suspension upgrade advice: 99 Sub
Ok, I posted this here as there seems to be more traffic here than in the suspension area. I looked around and could not find any info.
My 99 1500 Burb LT 2wd has pretty bad understeer at low speeds, especialy parking lot speeds. It seems like the front tires are just scrubbing instead of biting and turning.
The truck is all stock so far. I am runing stock 235/15's at 35 psi front and 45 rear per the door plate. I'll be increasing the fronts to 40 to see what happens, they look underinflated anyway at 35psi.
I do need new tires, but the problems is not just worn treads.
The stock running gear is all tight and in good shape. High speed is ok, a little wobbly on fast lane changes. Yes, I know, it's a big truck and will never handle like a 'Vette, I just want to tighten it up a little. Bigger swaybar? Tighter shocks? I'm an old off-roader, not really up on street performance...but my Jeep handles better, tho sure not smoother!
Thanks much!
suburbanjoe
Jul 27, 2011 8:12 PM
98chvytnk
May 11, 2011 11:07 AM
kawik1500
Nov 13, 2010 3:40 PM
SteveMc
Mar 22, 2009 8:07 PM
