New and a question
Old Apr 12, 2017 | 9:54 PM
Jkatracing's Avatar
Default New and a question
Hey guys! New to this forum and new to Chevy! Purchased a 2013 Suburban LT a few months ago and I'm pretty happy with my purchase.
BUT... lately (Since Monday), the truck just shuts off and then back on. It's happened on the freeway, in a parking lot, stopped at a light, etc... After a few days the only thing I've noticed is that the battery voltage starts to drop slowly to about 13.5 and then it cuts out.
i was hoping that maybe someone could point me in the right direction. I can do minor repairs so I'm hoping I can take care of it.
ed
Old Apr 12, 2017 | 10:12 PM
Jkatracing's Avatar
Some more info...
so I just got back and the suburban had power loss 3 times. When I got back, parked it and turned it off, the truck had no power so I couldn't lock it nor turn the truck back on. Waited a minute or two and I can hear the power come back and it started right up. Battery level was over 14
Old Apr 13, 2017 | 5:57 AM
I would check the battery cables for looseness or corrosion. Sounds like it could be a grounding issue. 13.5 volts is not really low and should not cause the truck to shut off.
Old Apr 13, 2017 | 2:01 PM
Jkatracing's Avatar
So I disconnected the battery overnight and trickle charged it. Also the connectors look super clean but I made sure it was tight.
it ran fine this morning but I'm going to look for the ground connection and make sure it's a solid and clean connection. I'm also going to potentially replace the super fuse at the battery terminal.
I also replaced the battery right when I bought the car.
Old Apr 13, 2017 | 2:05 PM
Check all of your cables, the connections need to be clean and not over tight, also check the connections at the mega fuse on the firewall.
Old Apr 17, 2017 | 5:51 PM
Jkatracing's Avatar
Since disconnecting the battery overnight and inspecting the connection, it's been running better lately. thanks for the suggestions everyone!
Old Apr 24, 2017 | 6:36 PM
Jkatracing's Avatar
it happened again over the weekend
going to check all connections and the megafuses.
