No dash light unless switch in "total on" position
Old Apr 14, 2014 | 3:43 PM
bigEd12's Avatar
Default No dash light unless switch in "total on" position
I have a 2002 Suburban and the Instrument Panel Lamp Dimmer only works in the "total on" position. Has anyone seen this? Just wondering if it is the "Headlamp Switch / Instrument Panel Lamp Dimmer Assembly",?
Old Apr 23, 2014 | 6:01 PM
Desert Gringo's Avatar
mine did that , I just think I had dirty contacts, as I sprayed contact cleaner on the assembly and then started moving the dial, and pressing the button fast a few times , now it works just fine. good luck
Old Apr 24, 2014 | 11:38 AM
bigEd12's Avatar
Thanks for that Desert. I thought it was just that also. I even got a hold of someone who gave a whole set of procedures to fix the contacts on that switch without having to buy a new one. I took mine apart and cleaned what I could as it appeared dirty and faded. The conductive traces were OK as I DVM'd it out and all was good. The resistive leads faded also as I rolled the ****. I ended up buying a brand new part. Once installing, it did the same thing. At this point, I'm suspecting a general electrical problem somewhere. Not sure where to begin from here other than I saw a few ground problems.
Old May 12, 2014 | 5:02 PM
bigEd12's Avatar
I bought a new switch online, plugged it in...same problem.
Took it to the shop, they brought a new switch...it worked. Everything I did was the same as there is not much at all to pulling and plugging in a new switch. Anyways, its working now.
advcomps
Sep 18, 2013 10:22 AM
Wild Turkey
Site Feedback
Dec 24, 2012 3:18 PM
