No heat on k2500/3500 suburban
Old Oct 20, 2018 | 5:57 PM
Yoruichi Shihoin's Avatar
Default No heat on k2500/3500 suburban
Having issues with getting the heat to work again on my suburban. Replaced the radiator and after that the heat ceased to work. I burped the system and it didnt change anything. Looking for help with this issue.
Old Oct 21, 2018 | 6:01 AM
geo1's Avatar
Are both hoses hot?the ones to and from heater core
Old Oct 24, 2018 | 12:45 PM
When running it seems there is no coolant in the lines coming from the intake on the back side. I tried to find the factory heater bypass, but it shows 2. One for if there is now rear climate control which is a standard 2 in 2 out valve. The second is a small what looks to be a switch with what looks like to ports for vacuum hoses and a 2 prong connecter. Ive already flushed the system 6monthes prior to the radiator blowing up and had perfect heat. Now there is nothing and just blows cold with a slight twinge of heat. That of which I'm assuming is just heat coming from the motor.
Old Oct 26, 2018 | 7:35 PM
4wBurb's Avatar
I don't know how long you have been trying but it took me forever. Park on a steep hill and let it run or use ramps and make sure there are no leaks at all.
