No Voltage to 1 Headlight
Old Mar 27, 2014 | 6:56 PM
trainwreck91's Avatar
Default No Voltage to 1 Headlight
installed hid when i first got the 07 suburban. the passenger side would work off and on sometimes. thought it was a bad connection or ballast. then finally went dead. thought it was just the ballast since i didn't hear it. so i ordered another set. went to swap it out today and nothing! got the tester out. nothing no voltage all the way back the the socket. driver side shows around 12. any suggestions?
Old Mar 27, 2014 | 7:44 PM
Was psgr side fuse OK?
Old Mar 28, 2014 | 3:39 AM
Actually did not check the fuses. Didn't think they would have separate fuses. Will check later
Old Mar 29, 2014 | 9:48 PM
Thanks shark. It was the fuse. But also the ballast was burnt inside as well.
garyv990
Feb 11, 2015 9:52 PM
mystrg
Mar 26, 2008 3:19 PM
schorner
Nov 1, 2006 8:42 PM
twfinch
Sep 26, 2006 2:38 AM
Jonathan93
Aug 8, 2006 4:03 PM
