OEM FILLIMENT BULBS V.S. LED BULBS???
Old May 27th, 2007 | 6:04 PM
wwotr's Avatar
Default OEM FILLIMENT BULBS V.S. LED BULBS???
The question below is for my 96 Tahoe:
I'm new to this and I am wondering first off, if theres any advantage between
a Clear LED Bulb VS a Red Colored LED Bulb, in as far as being BRIGHTER in my Tail Lights?
Given the answer to the question above, (in the "old School Days" we had 1156/1157 Bulbs).
What stock numbers are those bulbs in my 96 Tahoe?
I know they look the same, but the bases are flat instead of round.[/align]
In closing, has anyone made this conversion and how do they like it?
I'm looking for a simple "Plug-n-Play" solution without having to worrying
about burning wires, load equilizers ect.
[/align][/align]Respectfully,
Roger
"RATIKLE"
[/align]
Old May 27th, 2007 | 9:56 PM
tahoe07's Avatar
Default RE: OEM FILLIMENT BULBS V.S. LED BULBS???
If you have red colored lenses on your taillights then you would want clear LEDs for the brightest look.
The Red would only be needed for clear lens applications if you follow me.
Old May 27th, 2007 | 11:45 PM
jazejeff's Avatar
yes the clear ones will be brighter but as far as not having to modify them is not possible you need to put load resistors on them i sell the bulbs for $15 a piece and the resistors for $15 a set
Old May 28th, 2007 | 6:32 PM
tahoe07's Avatar
Superbrightleds sells them with resistor installed. They arrive plug and play. Rsearch the bulb size you need and look 'em up at superbright.
Old June 2nd, 2007 | 3:14 PM
wwotr's Avatar
Thanks Tahoe 07, but now I'm confused.[8D]
I went to: http://www.superbrightleds.com/
1) Everyone I've talked to says that WHITE/CLEAR LED's are the brightest.
Superbrightled's says that in the color spectrum , that a RED LED would be brighter due to the "type" of light they emmit. Anyone care to comment on this?
2)When it comes to Load Resistors, they're sigt says ther "already installed" but I cant see where that is?
3) They also talk about an LED Flasher, so I suppose I need one of those too?
In a perfect world, I'm looking for a BRIGHT LED bulb to replace my old style Filliment Bulbs
with a load resistor built in.
According to thier "Fitment Guide" my 96 Tahoe requires (2) 3057 LED'sTail/Stop/Turn/Running,
and (1) 3156 LED.
Just looking to see if I've got it straight
Roger
"RATIKLE"
Old June 3rd, 2007 | 11:07 PM
2) My guess is that if their LEDs have the same base as the OEM bulb, then the resistor is buried in the base.
Old June 4th, 2007 | 9:15 PM
tahoe07's Avatar
10-4 The bulb assembly has the resistor built in.
Hef88
December 24th, 2010 11:40 AM
Spaz563
February 11th, 2009 4:31 PM
Bubba992
November 8th, 2008 9:21 AM
Quick Reply: OEM FILLIMENT BULBS V.S. LED BULBS???
