Operator error - again !!!!
Old Apr 7, 2023 | 9:59 AM
Cusser's Avatar
Default Operator error - again !!!!
Horse trailer is back at repair shop, had two bent axles. Turned out that Mario Andretti (Mrs. Cusser) had not simply broken a steel partition panel bracket driving too fast on a pot-holed dirt road last summer, she also bent two axles (one has electric brakes). It also looked like she'd set the electric brake controller incorrectly and abraided/ruined the tires on that axle. Hoping to get out of that for under $1500......
Anyway, that's not the purpose of this post. I've been sick a week with severe seasonal allergies, and the rear hatch on the 2014 Yukon Denali would unlock, but would need to be raised manually (and closed manually) like on our 2005 Yukon Denali. No big deal for me, she likes the electric opening and closing. We had a 2011 Yukon Denali that wouldn't open automatically or stay open, I installed new lift cartridges to fix that. So, being sick, I just re-ordered a pair of new lift cartridges through Amazon for $28. Yesterday I felt good-enough to replace those (used a 6-foot pipe and floor jack to support the hatch), but that didn't fix the non-opening/non-closing issue. I started looking at fuse identifications since the actuator motor for this made no noise or motion at all. Just then I remembered there's some button inside (I never actually drive this vehicle) for the rear hatch, and sure enough, she had switched to the lock position, so easy fix.
So operator error again, just like with the failure to realize the side rails automatic operation could be turned off.....don't bet on her ever reading the operator's manual.....
I left the new lift supports on, $28. So I have the old ones as spares.....
Old Apr 7, 2023 | 11:46 AM
you saved $ cause it would have been $100 for a shop to diagnose it.
Old Apr 7, 2023 | 7:19 PM
Cusser's Avatar
These days: likely.
Old Nov 13, 2024 | 9:00 AM
Cusser's Avatar
Originally Posted by Cusser
The rear hatch on the 2014 Yukon Denali would unlock, but would need to be raised manually (and closed manually) like on our 2005 Yukon Denali. No big deal for me, she likes the electric opening and closing. We had a 2011 Yukon Denali that wouldn't open automatically or stay open, I installed new lift cartridges to fix that. So, being sick, I just re-ordered a pair of new lift cartridges through Amazon for $28. Yesterday I felt good-enough to replace those (used a 6-foot pipe and floor jack to support the hatch), but that didn't fix the non-opening/non-closing issue. I started looking at fuse identifications since the actuator motor for this made no noise or motion at all. Just then I remembered there's some button inside (I never actually drive this vehicle) for the rear hatch, and sure enough, she had switched to the lock position, so easy fix.
UPDATE: 1.5 years later, the left lift support failed, so I installed one of the saved lift supports. Fixed. There was no resistance at all in the failed support, and there was evidence of oil/dust visible near its lower mount.
jstein1206
Dec 26, 2022 11:00 AM
RJK
Aug 2, 2019 5:50 PM
gruvenparts.com
May 21, 2018 8:09 AM
gruvenparts.com
Apr 9, 2018 9:36 AM
Crich
Jan 29, 2015 8:13 PM
