overnight battery drain
Old Jun 26, 2017 | 1:37 PM
PABLOZ's Avatar
Default overnight battery drain
2004 Suburban current drain is 1.3 amps intermittent.
pulled fusees did not help went back to .11 ma. which i assume is the keep alive for clock etc, thinking ignition switch,?????
Old Jun 26, 2017 | 2:05 PM
If it went back to .11 ma when you pulled the fuses then it did help. Pull them one at a time and see which one gets it to the .11 ma and that will be the circuit. That is if I understand you correctly.
