P0443 07 tahoe z71 help needed
started as a P0304, I did the injectors, the plugs and wires, the purgesolenoid. Now Im getting a P0300 and p0443 has me pretty confused. A few months ago I did the vent valve solenoid to fix my fueling issue(Ie pressurized gas tank). Tried everything, also replaced mass airflow sensor. Need a mechanics advice. White smoke and loss of power. Misfiring stumbling and fumbling.
coolant levels are steady, exhaust smells like gasoline, and its burning oil faster than usual. My dad and I have been colaberating he thought maybe MAP sensor or oil pressure orrr the AFM and it being stuck in 4 cylinders.
If my memory serves me it used to idle around 40 now it’s closer to 25 I chalk that up to the Miss fire. It seems likly that it’s a vaccum leak or something wrong with evap system. I will look into getting one to your point.
sookra93
Dec 3, 2013 2:19 PM
