parking brake problems...
Anyone have any problems with their parking brake? I never use mine, because when I do, it freaks out when I release it. It will keep thinking it is on and the rear park assist light will keep flashing saying its disabled or something like that. I have to play with the parking release for it to finally realize that it is not engaged.
Also on more than one occasion, the alert for rear park assist disabled keeps flashing and beeping that it ends up blowing a fuse. This fuse is the amp fuse located in fuse compartment under the hood. When this fuse blows, I loose all audio.
Anyone have anything similar with theirs?
Its a 2007 LT3.
As far as I can tell the parking brake gets disengaged when I release it. If I let go of the brake, it will roll forward, so it seems to be working correctly. Its as if the parking brake release handle has a sensor of some sort. If I put pressure on the upper part of the release handle, the light goes off as it should.
Hopefully my description makes sense
kaptain howdie
December 16th, 2014 9:20 PM
Greg O
September 8th, 2006 3:21 AM
