Plugged hose behing LF tire?
Old Mar 6, 2007 | 7:14 PM
BigAlCaribe's Avatar
Default Plugged hose behing LF tire?
New member here, was 7 months researching a new Avalanche and ended up with a Z71 tahoe instead. This site has been a great source of information and research and I hope to give back as well. I found what seems to be a plugged hose/tube dangling behind the top of the drivers side front tire on my 07 Z71 4x4 LT3 Tahoe, it seems to come from a budle of wires in the engine compartment. Any ideas on what this is for? Should it be dangling down or should I push it back up and tie it down?
Thanks,
-Al
Old Mar 7, 2007 | 12:30 AM
tahoe07's Avatar
Default RE: Plugged hose behing LF tire?
I have a wire that connects in that area. It comes out from under inner wheel well in flex tube. It connects there to a smaller line and runs to the upper control arm to the final plug before running to the inside of brake rotor. Gotta believe its ABS. If yours was off though should have thrown a code.
Old Mar 7, 2007 | 9:20 AM
Hardin Thicke's Avatar
I've seen it too while searching for my block heater plug (still haven't found it). Assuming it's a 4x4, I'm going to take a guess and say it's the front axle vent.
Old Mar 7, 2007 | 9:58 AM
Thanks to all for the input, I don't have any warning lights up or anything. Here is a pic of it, just seems strange for that tube to be just hanging down like that. If it makes a difference, it comes from a wiring harness and seems to be sort of a black rubber material plugged by a small black plastic piece.
much aprreciated,
-Al
[IMG]local://upfiles/7310/58D72D2CD9684001A5E885189B14D36B.gif[/IMG]
Old Mar 7, 2007 | 2:58 PM
I agree with Hardin Thicke. It sure looks like an axle or tranny vent tube. Will check mine Fri. when get back from body shop.
Old Mar 7, 2007 | 6:45 PM
tahoe07's Avatar
Now I got you. Mine is secured to the bundle of wiresjust belowthe blue connector coming out from under the fuse box. Mine is pointed straight up in the air so I guess it doesn't matter which way you secure it.
It runs down to the top of the transfer case.
Old Mar 7, 2007 | 6:57 PM
The higher up, the better cuz then you can go thru deeper water. Looks like his has fallen down for some reason.
Like any of us are going to do much of that.
Old Mar 7, 2007 | 9:05 PM
I just went outside and tucked it back up by the blue plug. Looks a lot better that way and it's also out of harms way. It also looked like it could collect a little water when hanging upside down.
Thanks!
-Al
[sm=gears.gif]
Old Mar 8, 2007 | 3:13 PM
jbcobb's Avatar
Suggestion: Go see the dealer and have them check it. You have a warranty.
Old Mar 25, 2007 | 1:41 AM
Checked mine today and it appears to be the front axle vent tube.
