Possible Automatic Transmission Problem
Old May 14, 2014 | 3:39 PM
garrisond's Avatar
Default Possible Automatic Transmission Problem
I have a 2003 Tahoe with I believe a 4L60-E transmission. I have noticed what feels like a miss as I drive around 40-50 mph. Shifting has seemed a little different. This morning around 45 mph I noticed the tachometer went from 2k to 4k with what felt like no torque to the rear end as if I had shifted to neutral. After a few seconds or so it seemed to catch hold again and the rpm went back down. Could this issue be something other than the transmission?
Old May 14, 2014 | 5:42 PM
Sergio Lisboa Machado's Avatar
It seems to be it, you will need to open it and inspect, at least buy a transmission master repair kit.
Old May 14, 2014 | 9:40 PM
Joe In NY's Avatar
Have you tried checking the fluid level? Sounds like converter shudder and low fluid level causing your pump to draw air and which allows the clutch packs to disengage and reengage rapidly. Also causes gear hunting...
Old May 15, 2014 | 4:55 AM
garrisond's Avatar
Thank you.
Old May 15, 2014 | 4:56 AM
garrisond's Avatar
Yes, I have and it appeared to be fine but I will check it again. Thank you
danyel.34
Feb 3, 2014 5:24 PM
missy
Oct 24, 2012 3:36 PM
lcfake
Aug 14, 2011 5:06 PM
Victoria
Mar 29, 2011 9:10 AM
isaac_22
Jan 8, 2008 10:25 AM
