power door lock issues
Old Sep 14, 2008 | 7:11 PM
joeysworld's Avatar
Default power door lock issues
1999 Tahoe 4 door 4x4
The driver/passenger side power door locks are intermittently or not working at all. The drivers side PDL never responds when the switch is used, and the passenger occasinally works. The rear barn door does't work as well.
When I took the door panel off on the drivers side, and when I inituated the switch, I could see that there was a very slight response.
The 2 rear doors work fine when the switch is used and when I use the remote.
Is there a relay that may be causing this?
Any help appreciated.[/align]
Old Sep 15, 2008 | 11:21 PM
joeysworld's Avatar
Default RE: power door lock issues
I ended up replacing the 2 front power lock modules with an extra set that I had.
I took off the door panel, and unscrewed about 8 screws from the skin with the power lock moduel. Pulled the skin outward some, lifted off the anchor, and unscrewed 3 screws from underneath the moduel. Along the way I lifted the boot that is on there for protective reasons.
Problem solved......really weird how just the 2 doors in the front went bad.
cnterline
40
Dec 9, 2021 11:48 AM
nechevy
Dec 21, 2020 5:50 PM
refinisher
Jun 12, 2020 12:51 PM
Mastiff
Jul 12, 2010 8:39 PM
davbell22602
Mar 10, 2010 8:36 PM
