Power Door Lock progressive problem
Old Jun 21, 2012 | 5:26 PM
mriepe's Avatar
Default Power Door Lock progressive problem
2008 Chevrolet Suburban. Neither the remote keyless entry or switch on driver's door will operate selective power door locks. First the driver door lock failed, the other 3 worked fine. Weeks later, the back door behind driver lock failed, the other 2 worked fine. Yesterday, the other back door lock failed, and only the passenger door works OK. All manual buttons work fine, no abnormal resistance felt. When you hit the remote keyless entry or button on the drivers door, no clicking is heard in the failed doors.
Would appreciate ideas.
Old Jun 21, 2012 | 6:00 PM
the door lock actuators are a common problem. You probably need a new one...or two.
Old Jun 22, 2012 | 9:18 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> mriepe,
I agree, it sounds like an actuator issue. I recommend consulting with a certified technician.
Louis
GM Customer Service
Old Jun 22, 2012 | 9:33 AM
SabrToothSqrl's Avatar
Default Door Locks?
LOL, you want something on your GM to WORK? that's cute.
my Tahoe's gone through THREE power door lock actuators under warranty...
Anyone know where the CEO of GM lives? I'd like to have a conversation with him.
Old Jun 23, 2012 | 3:00 PM
On my 2007, they had to replace a small module under the dash above the parking brake.
cnterline
40
Dec 9, 2021 11:48 AM
refinisher
Jun 12, 2020 12:51 PM
figuee19
Jan 26, 2016 9:00 AM
Mastiff
Jul 12, 2010 8:39 PM
davbell22602
Mar 10, 2010 8:36 PM
