Power Locks?
Old Nov 17, 2018 | 2:34 PM
Slvrcvc's Avatar
Default Power Locks?
Both front doors stopped unlocking/locking at separate times. After looking at different posts online I saw many people had issues with their lock actuators going bad so I went ahead and replaced mine (Non OEM I ordered on Amazon). The passenger worked just fine but the driver side will only unlock but won’t lock. Thought I received a defective one so I exchanged it and the second one did the same thing. Was told to just go ahead and get an OEM one from the dealer so I did and same thing...only unlocks but won’t lock. Checked the four fuses on the side of the dash which only seem to affect the rear two doors either way and they are good. Has anyone else had this problem? Or does anyone have an idea of what it might be so I can check it....all the posts I’ve came across—replacing their actuator fixed their problem. But after trying three new different actuators from three different places...I’m pretty sure something else is the problem. —2007 Tahoe LT
Old Nov 17, 2018 | 4:07 PM
I think there is a module in each door that the computer talks to for various functions. You might swap modules from another door to see if that is the problem.
Old Nov 20, 2018 | 8:32 AM
a55bruce's Avatar
If the key fob and the door switches misbehave the same way, then it's the door module or a bad connector/wiring at the door module. As 73Shark said swapping would be a good test. If it's just the door switch acting up then check the switches.
Old Nov 20, 2018 | 3:52 PM
Slvrcvc's Avatar
Where exactly is the door module located? It’s been a few days since I swapped out the actuators and I dont recall seeing one on the door. Tried searching for the location online since I didn’t drive it to work today but I get back threads on the RCDLR....is that what you guys are referring to? & by the way thank you guys for your help with this.
Old Nov 20, 2018 | 5:17 PM
a55bruce's Avatar
Originally Posted by Slvrcvc
Where exactly is the door module located? ...
I think on this model it is part of the door/window/mirror switch assembly. Check to see if the connectors have any loose wires, loose pins, moisture or corrosion.
