Power locks not working
Old Mar 9, 2014 | 3:33 PM
Fiddleman4's Avatar
Default Power locks not working
I have a 1997 Tahoe and my power locks are not working. I have tried to replace fuse 13 as that is the the fuse that controls the locks but as soon as I put the new fuse in it blows. I do not know what to do from here. I am not a mechanic nor am I an electrician but I am willing to try anything cheep. Thanks for your time and help!
Old Mar 9, 2014 | 4:35 PM
Welcome to the forum...
Troubleshooting is free if you do it yourself, however it will require removing door panels and using a multi-meter or DVM...
But before doing anything other then opening the doors the easiest thing to check is the wires that pass through the body to the doors at the hinge location... check for any pinched, cut or shorted wires...try the fuse with all the doors opened...
The next place to check would be the door lock switches, I would suggest the drivers side first, pull the switch and disconnect it, see if the fuse still blows...
unbreakable
12
Aug 17, 2015 9:32 PM
mideerslayer
Sep 13, 2012 9:42 AM
btlaing
Apr 13, 2012 2:10 PM
HVACPhil
Astro
May 18, 2010 4:32 PM
noslocars
Nov 6, 2009 5:26 PM
