power loss after 3000 rpms at WOT??help!
Old Jan 23, 2010 | 10:44 PM
  #11
Clogged cat can cause low vacuum.
Old Jan 23, 2010 | 11:04 PM
  #12
99yukon's Avatar
The 11.2 is at idle. It says it supposed to be around 18-20. My catalytic converter does look like its getting hotter than normal. Also looks like its getting rusty maybe from the heat of it being clogged Im guessing?I don't know what my bank 2 Stft and Ltft are supposed to be at idle but they don't look right compared to bank 1.
Old Jan 24, 2010 | 12:31 PM
  #13
MDTAHOE's Avatar
Professional Mechanic
What happens to the vac reading if you rev it up and hold it up?
Old Jan 28, 2010 | 6:11 PM
  #14
99yukon's Avatar
I used freeze frame data I didn't use a vaccum gauge. I will try to pick one up and see what the readings are.I was going to replace the cat in a couple of days but isn't it pointless if there's something else wrong with the truck? I don't want the cats to go bad again because if that happens i'm just going to get fake o2's and straight pipe the catalytic converters.Seems like this truck has been a money pit so far since ive owned it for a year but the more money i throw in it the more new parts are going on it so guess its not that bad.
Old Jan 29, 2010 | 6:00 PM
  #15
aaron8301's Avatar
Default Cat
First thing I though of by reading the title was clogged cat. Happened to me on a different vehicle. You said you replaced one cat, why not the other? I'd suggest at least having a muffler shop do a pressure test. They'll usually do it for free, knowing they'll get to charge you to fix the problem they might find (kind of like free batt/alt checks).
Old Feb 28, 2010 | 7:28 PM
  #16
stites31685's Avatar
my 96 has the same problem, i replaced the regulator and the pump, plugs, wires, no codes for any thing, and no difference in performance. monday, im gonna run open headers and see if that makes a difference. ill let u know
Old Mar 1, 2010 | 8:22 PM
  #17
dissconnected cats. sounded cool, but no difference
Old Mar 11, 2010 | 8:37 PM
  #18
I replaced the pump basket and now all is well.
Old Apr 10, 2021 | 5:44 PM
  #19
Barry McCoy's Avatar
what’s pump basket?
Old Apr 11, 2021 | 8:38 AM
  #20
repairman54's Avatar
Originally Posted by Barry McCoy
what’s pump basket?
That post is from 11 years ago. Do not expect a answer. Check the dates your replying to as many posts / posters are one and done.
Pump basket is the in tank fuel pump assy. .
KaylaBaby1141
Dec 23, 2020 11:38 AM
Miranda Lamb
Avalanche
Apr 14, 2019 2:02 PM
GloverEggs
Nov 21, 2013 6:40 PM
captcave
Apr 22, 2012 3:03 PM
miscou1
Feb 1, 2012 8:28 PM
