Power mirror issue
Old Mar 19, 2020 | 3:23 PM
99fxst99's Avatar
15 Year Member
Default Power mirror issue
2010 Suburban LTZ-
My right side mirror is more and more moving the glass only, not the whole mirror, to the extreme outside angle when I shut off and restart. Tried several different settings on the park assist mirror setting to no avail. Anyone have any suggestions?
Old Mar 19, 2020 | 3:36 PM
I don't understand. Can you take a picture of what you mean?
Old Mar 19, 2020 | 7:57 PM
Rednucleus's Avatar
So the glass is moving but not the entire housing??
Try cycling the housing full closed and open a few times.
Old Mar 19, 2020 | 9:44 PM
intheburbs's Avatar
So it's pegging the mirror glass to the extreme outside? I'd wager a problem with the switch. Have you gone through the drive through recently with your windows open when it was raining? Did your power windows/mirrors switches on the arm rest get wet? It was a known problem for Bosch. I would disassemble the door, remove the switch in the arm rest, and clean it out with alcohol and compressed air. Worst case, buy a new one.
Old Mar 24, 2020 | 7:33 PM
markc's Avatar
I agree. I couldn't get anything the door buttons control to work. I disassembled the entire switch and the circuit board was visibly dirty. cleaned it with alcohol and a cotton swab. works perfectly now, and took 15 minutes. be patient with the tabs so they don't break.
weewun
May 18, 2012 7:41 AM
zack_novak
Aug 10, 2011 5:34 PM
tahoe07
May 25, 2009 11:33 AM
Rooster
Jan 27, 2008 6:43 PM
