Power Steering and Brake Failure
Old Jul 13, 2009 | 10:50 PM
jwl0811's Avatar
Default Power Steering and Brake Failure
My wifes 2000 Suburban just lost it's power steering and brakes tonight. Should I be looking at the power steering pump or brake booster? Anybody ever experience this? Any input would be appreciated. Thanks.
John
Old Jul 13, 2009 | 11:55 PM
MDTAHOE's Avatar
Professional Mechanic
If you lost both power steering and power brakes at the same time most likely the truck has hydro boost. Instead of having a vacuum brake booster it use a hydraulic booster run off the power steering. I would suspect that your P/S fluid has all leaked out so you need to find out where it leaked from. If the fluid is still full then your pump may have stopped pumping. To tell if you have hydro boost look to see if the booster has 2 lines going to it tied into the power steering pump, or if it has a single vac lime going to it.
qzack1
Aug 28, 2011 12:50 PM
Hilti55
Feb 13, 2011 10:59 PM
DgDaviso
Apr 27, 2010 11:08 AM
jasonhpi
Apr 2, 2010 1:04 PM
abeebe
Sep 27, 2006 2:20 PM
