problem with tahoe push start button!
hello
i installed push start button to my chevy tahoe 2011 and every thing is ok
only i found problem with the brake light. it doesn't work when the car is off only it works with the ACC and ON switch.
when i need to start my car with push start button i must press the push button to ACC then ON and then the third press whith brake pedal the car will start
i need any idea to make car starts whith the first press on brake pedal and push start button.
thanks alot.
thanks alot.
hello
thanks alot.
thanks alot.
and it is PKE (passive key entrey) with push start button
search in youtube you will find alot of videos
i will upload pictures for my new system.
thanks
My wife's 2013 Dodge Journey has the keyless entry and push button start...
Its sweet, the column doesn't even have a place for the key
With the keyfob in your pocket or purse you walk up to the vehicle grab the handle and it unlocks... get in, put your foot on the brake pedal and press start.. When you get out, you close the door and press a small button on the door handle with your thumb and all the doors lock
I'm not interested in an aftermarket one but a factory one would be sweet...hopefully its an option on the 2013 or 14's
my aftermarket remote system
when you approach the car within the range 2 meters the car unlock and when you walk away from the car will lock automatically.
when you missing the door opened the horn will honk twice for three times then the doors will lock immediately.
it is a smart system and i love it.
