pump stop when pumping fuel 07 tahoe
hello forum..
hope y'all can help me
07 Tahoe ltz...everytime i go get gas.. almost every two days now.. .lol
i put the nozzle in all the way.. and begin filling it pumps a gallon or two and stop i have to stand there and keep stoping and going to get a full tank.. hope i explained it well and hope someone knows what I'm saying and feels my pain.. such pain in the neck to fill up gas.. not sure what the problem is.. if i put the little lever to auto-fill it stop after a gallon or two it clicks and have to do it again after a gallon it clicks off again.. so frustrated ..
help please..
help please..
leslie (August 27th, 2021)
I have had that happen a few times before. pretty sure it has something to do with the sensitive pumps and how they pull out the fumes vs letting them go into the air like in some states. if they cant get a good vacuum going then they shut off. I thought I read something about the filler neck going to the gas tank can have issues at times also
I assume you have tried many different pumps?
usually after a few tries it fills up all the way for me w/o issue.
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> The fueling issue is an industry wide issue with variation in specific fuel nozzles throughout the fuel station industry.
Until the fuel station industry can replace the nozzles with the improved versions, please try another pump and/or another fuel station.
Louis
GM Customer Service
Louis
GM Customer Service
Now, for a mechanical angle, check out thread https://chevroletforum.com/forum/ava...problems-5253/. The EVAP vent valve can become clogged but not enough to trigger a trouble code.
got it
i figured it out.
as for the pump issue, have u seen that ford has capless fillers now on almost all their cars?
I experienced it on a loaner escape, and it's very cool. why the hell did it take so long to put that on a car, and why aren't they ALL that way?
