Question About Electric Windows.
Old Dec 20, 2017 | 2:57 PM
Raymond 1960's Avatar
Default Question About Electric Windows.
The drivers door window stopped working properly.Upon opening the the door panel I discovered that the wire cable was broken.This cable feeds into a small motor and actuates the up and down motion of the window.
Am I able to just buy the broken cable or do I have to buy the whole assembly?
PS: This pertains to a 2002,2500,4WD Suburban.
Old Dec 20, 2017 | 3:53 PM
You can also splice the wires back together. Very simple procedure,
Old Dec 21, 2017 | 11:34 AM
I've never spliced a braided wire before.Could you possibly explain how this may be done?
Thank you.
Old Dec 21, 2017 | 3:28 PM
kevinkpk's Avatar
It sounds like the cable from the lift motor to the guide is cut. You can get that part at parts store such as autozone.
Old Dec 22, 2017 | 12:00 PM
Thank you,that's good to know.I'll stop by there this weekend and report back here.
Old Dec 22, 2017 | 9:49 PM
I have soldered them back together before. I also used heat shrink tubing.
