Radiator fan runs at cold start up
Old Mar 29, 2023 | 10:10 AM
mlupone's Avatar
Default Radiator fan runs at cold start up
I have a 2004 Suburban Z71 with 205K miles.
QUESTION: Should the radiator fan run at initial start-up when the engine is cold?
I have never noticed whether it runs or not when you start the engine from a cold start. Yesterday, I noticed that the dashboard temperature gauge wasn't operating; e.g. the needle was sitting at/just below 160 degrees after driving for 30 min or so. I thought the engine coolant temp sensor was bad, but this morning the dash temp gauge was reading properly. I also noticed that the fan was running from a cold start. Since the fan is connected to the water pump pulley and the water pump is continuously running when the engine is operating, shouldn't I expect the fan to run continuously as well?
As an aside, the cooling system has always been properly maintained and the water pump was replaced at 150K miles.
Matt
FifthWheelPuller
1988 - 1998 (GMT400)
Dec 31, 2024 8:49 AM
ChevyCelebrity86
Mar 2, 2023 6:56 PM
Haciyev Mehemmed
Feb 2, 2021 11:22 AM
bhailey
Feb 16, 2014 8:09 PM
xswinnyx
May 13, 2006 1:01 PM
