Radio cutting out!
Old Aug 21, 2006 | 11:49 PM
timdogg1313's Avatar
Default Radio cutting out!
My radio in 1997 4 door 4x4 tahoe is cutting out and won't come back on until you turn the key off and then turn it back on again. the radio does not lose power, just no sound after about 30 seconds to a minute of play. I tried changing the factory unit out with an aftermarket radio and it still does the same thing. Thanks for the help
Old Aug 22, 2006 | 12:01 PM
ZX1100F1's Avatar
Default RE: Radio cutting out!
In your case there is an obvious problem with the power source to the radio. Could be as simple as replacing a fuse that is faulty but not quite as bad as most that burn out.
Old Aug 22, 2006 | 11:51 PM
I've got it somewhat figured out. I think a wire is shorting out on the right side of the vehicle. I balanced the radio all the way to the left and it hasn't cut out again. Thanks for the help.
timdogg1313
camp4040
Oct 15, 2021 4:51 PM
vjam
Jul 18, 2010 4:02 PM
Logansmom121604
Avalanche
Nov 17, 2008 10:27 PM
LVHoe07
Oct 24, 2007 10:50 AM
robbiestuff
Sep 3, 2006 10:22 PM
