radio removal
Old Jul 6, 2006 | 1:42 PM
weirleader's Avatar
Default radio removal
trying to get at the back of my 2003 Tahoe factory radio - want to connect an XM receiver through the Auxiliary (there is one, isn't there?) - but the cable's too short. I can get a couple fingers behind if I also remove the A/C panel, but not enough to get an idea of how to disconnect. I probably am being overcautious, but really don't want to rip out the wires.
Any tricks? Should there be plenty of wire? Do I need to remove the whole dash top??? (I hope not)
All help appreciated!
Old Jul 7, 2006 | 11:54 PM
viperjuice's Avatar
Default RE: radio removal
as far at i know, you set the parking brake, put the car in 1st, remove the front trim off of the dash, unscrew the radio screws from the front, pull the radio out.. thats all there should be. I work at a dealer and have never had that problem. so if you have wires keeping the radio in, then they might be pinched behind the hvac control head or the ipc, but now the top of the dash does not need to come out unless someone screwed something up before. and yes there is an auxilary for the 6dish changer or tape player on some models, you'd have to get the auxilary harness and splice into it somehow.
adamant
Feb 15, 2009 8:49 AM
j061006
Jun 16, 2008 9:12 AM
cgmoran
Sep 1, 2007 4:43 PM
JohannesKepler
Mar 24, 2007 2:10 AM
