Rear blower inop
Old Sep 9, 2016 | 5:19 PM
  #11
rtkachuk's Avatar
Originally Posted by Helpu
Hello rtkachuk. Not sure if I replied to your question already. Tell me what you have done/troubleshoot so far and your mech/auto elect savviness
If I tap the passenger rear cargo area plastic shroud the blower kicks on. Could this be the motor? If so, do you have a part number?
Old Sep 9, 2016 | 5:50 PM
  #12
Helpu's Avatar
Sounds like you might be in luck and something minor. Could be a loose wire/connection. Take off the 1/4 panel and check the connections on the blower FSR unit. Check your ground wire while you're at it make sure it's not loose make sure the nut is on tight. Check the blower make sure there is nothing jammed in there causing it to be intermittent. Motors either good or no good, there is no in-between. Also check the thin wire(sensing wire---purple) for good connection. I did not need to replace my blower motor( so I would not have a part # but that's an extreme case and I tend to think your problem is not the motor.
  #13
Helpu's Avatar
Old Jul 31, 2017 | 9:58 AM
  #14
2005Tahoe's Avatar
Default No power to rear AC 2005 Chevy Tahoe
Not sure if this are old post or current issues but I just fixed mine and if you need info let me know. Maybe I can help.
I was wondering if anyone could give me some intel on my rear AC problem. I am not getting any kind of air from the rear ac. I use the front and rear controls and no luck. I have not done anything to it at all because I wouldn't know where to start . Can someone please help . Thank you
Old Jul 31, 2017 | 4:39 PM
  #15
Helpu's Avatar
Hello
Still having AC issues? Give full details of the issues you are having and what you have done so far. Reply to this email as I am not good with navigating the forums. I had an initial AC issue last year I fixed myself for $30 instead of $1200 at dealer, troubleshooting then replacing the Aux. rear AC control module but then a month ago I ran into another issue which I fixed myself for $60 instead of $500 at the delaer. Every little detail is very important for good diagnosis and hopeful I can help resolve your AC issues.
Thx
Filipo
Old Jul 31, 2017 | 4:48 PM
  #16
Helpu's Avatar
1. Is the front AC and Heater running normally
2. From what you said, the rear Blower does not come on at all when the controls(rear) are in right settings correct?
3. Does your car have both a front and rear overhead console controls for the rear AC? and you have set these controls in the correct positions but still no rear air, correct?
Old Jul 31, 2017 | 4:57 PM
  #17
Helpu's Avatar
You can reply here. I can get ur message
  #18
Helpu's Avatar
U can reply here. I can get ur message now
Old Jul 31, 2017 | 9:07 PM
  #19
2005Tahoe's Avatar
Hello
Thx
Filipo
ok so my rear ac is not working at all it does not turn on! I will turn on the front one and use the AUX in the back and the front and nothing . I haven't tried anything at all to repair it .
Old Aug 1, 2017 | 12:10 AM
  #20
Helpu's Avatar
Can't help if you do not give good information.
What is your level of mechanical or electrical know how?
Answer the three(3)questions I posted directly and individually.. Do not bundle the answers together as it gets confusing
