Rear Brake and signal lights
Old Nov 8, 2017 | 10:55 AM
TJSCanton's Avatar
Newly Registered
Default Rear Brake and signal lights
I have a 1998 Suburban and the right and left signal and brake lights are not working (same bulb). The upper (3rd brake light) works fine. I have replaced the bulbs on both, and checked for cracked/broken wires in the back where I can see the harness/wiring. I didn't think there was a fuse that is for these lights and not the third brake light, but maybe there is?. THanks in advance for any advice.
Old Dec 20, 2017 | 8:20 AM
Yogi's Avatar
Try looking along the underside of the frame for a junction that your lighting harnesses are connected to. Depending where you live, the junctions can get moisture within them and create corrosion in turn causing a lighting problem. Just pull the weather pack connectors that hook up to the junction and check them for corroded pins or sockets.
