Rear Cargo Dis-assembly
Hey, I have a 2002 Tahoe, My rear AC vents dont blow air at all. It doesnt matter if the front controls are on or the rear, I was thinking it may be the relay that needs to be replaced.
My question is...How do I get to the rear blower motor and relay and resistor?
Is the dis-assembly hard? Does anyone have a right up on how to get to the above mentioned items?
I have done many searches and cant find any info on how to do this.
Thanks in advance for your time and help.
P.S. The front vents and AC work great. This is why I am thinking the relay or resistor went out on the rear.
Have you checked all the under hood fuses and relays, maybe walk a few of the similar ones to see if anything changes....
Welcome to the forum by the way..
Sorry can't upload the PDF its too big but here is the text...
2002 Chevrolet Tahoe - 2WD | Avalanche, Escalade, Suburban, Tahoe, Yukon (VIN C/K) Service Manual |
Rear Quarter Trim Panel Replacement - Right Side
(Utility)
Removal Procedure
1. Remove the rear seat. Refer to Rear Bench Seat Replacement in Seats.
2. Remove the Third Pillar trim panel. Refer to Third Pillar Trim Replacement .
3. Remove the garnish molding. Refer to Body Rear Corner Garnish Molding Replacement .
4. Remove the door sill plate. Refer to Liftgate Door Sill Plate Replacement .
5. Remove the quarter panel trim screws.
6. Remove the quarter panel trim from the vehicle.
Lift the quarter panel to release the quarter panel from the vehicle.
Installation Procedure
1. Install the quarter panel trim to the vehicle.
Notice: Refer to Fastener Notice in the Preface section.
2. Install the quarter panel trim screws.
Tighten
Tighten the screws to 2 N·m (18 lb in).
3. Install the door sill plate. Refer to Liftgate Door Sill Plate Replacement .
4. Install the garnish molding. Refer to Body Rear Corner Garnish Molding Replacement .
5. Install the Third Pillar trim panel. Refer to Third Pillar Trim Replacement .
6. Install the rear seat. Refer to Rear Bench Seat Replacement in Seats.
(Utility)
Removal Procedure
Tighten
Thank you for the welcome. And thanks for the info. I have checked all fuses. Im still a newby to this stuff and I don't have a multimeter nor do I know how to use one.
Is it possable for you to send me the PDF link or the PDF itself to my email adress?
Xile562@gmail.com
Thanks a bunch man, I appreciate it.
Xile562@gmail.com
How to use a multi-meter...
How to Use a Multimeter - wikiHow
An inexpensive meter to start out with...
Search results for: 'multi meter'
Good luck and keep us updated with what you find so we can continue to help you and others...
I got it fixed, All the panels in the rear were easy to take off. I checked all the connections and everything seemed fine. Went once more up to the front drivers side fuse box and pulled all the AC fuses and replaced them. It ended up being the 25 fuse that was burnt out. It was not blown...just burnt. Anyways, thanks everyone for all the help. I was glad it was just a burnt fuse.
P.S. I know that fuses are the first thing to check and I did check them all before I started. For some reason I just got a feeling I needed to replace them seeing how all of them had been in the vehicle for 170,xxx miles. Thanks again.
greggk
September 11th, 2010 1:51 PM
ericnottelin
June 29th, 2010 12:37 PM
jzlharvey
December 28th, 2007 10:35 PM
