Rear climate control freaking out
Old Nov 12, 2020 | 9:58 AM
Jason Sims's Avatar
Default Rear climate control freaking out
Hey everyone, I haven't been able to find a thread on this particular issue and wondered if anyone had an insight on repairing it. I have an 04 Tahoe LT that has the auto climate controls up front and the rear climate control that can be controlled up front or in back depending on which setting it's on. I can be driving with the rear controls off or just barely on and out of nowhere it will kick on the rear full blast, then a few minutes later will kick off like nothing happened! Sometimes it'll be full hot, sometimes it will be full cold and it doesn't seem to matter at all where the dials are. On top of that, while I haven't checked it extensively (always up front driving) I don't think the aux controls do anything when it is in that mode as I recall. The front climate works flawlessly. Could it be one of or both of the rear controllers? Perhaps a rear cabin sensor? Any advice would be appreciated.
On a side and unrelated note... I have the bose system with an aftermarket stereo that has the bose amp still in place and 95% of the time all works great... Except when it's really cold outside, there is no sound through the speakers. The stereo appears to be operating normally, just zero sound, no fuzz no anything. Like maybe the amp is too cold to kick on? Has anyone had this issue?
Old Nov 12, 2020 | 10:46 AM
PNW NBS Z71's Avatar
Check this link out: https://www.fixmyoldride.com/Chevrol...pos=3&at_tot=4
Is especially important in rust belt areas.
Old Nov 16, 2020 | 9:49 AM
Jason Sims's Avatar
Thanks PNW, I'll have to check out those cables. I have checked battery connections, but not the cables and lower connections. It has had some other electrical demons in it in the past, so maybe this will be a positive step either way. I'm not in the rust belt, but here in northern california we get a range from from low 20*'s all the way up to 115* and all sorts of moisture/rain in the winter. I could see moisture in those cables freezing and causing issues.
Old Nov 16, 2020 | 1:54 PM
Check this link out: https://www.gmfullsize.com/threads/h...d%20alternator
If you plan on keeping the rig, you should do this upgrade.
Sharpshooter23
Feb 4, 2020 9:30 PM
Pochant24
Feb 4, 2020 8:55 PM
Steelman512
Mar 3, 2013 9:52 PM
rjdjbd
Dec 19, 2011 7:16 PM
fbickley
Nov 1, 2007 2:30 AM
