Rear end replacement
Old Aug 29, 2006 | 1:25 PM
funky_junk's Avatar
Default Rear end replacement
I have a 2007 LTZ with the 3.43 rear end. I have a 4200lb travel trailer and a few people told me I am going to have some trouble with it. I wonder how difficult it will be to find a 3.73 rear end and have it installed. Any guesses?
Old Aug 29, 2006 | 4:20 PM
ZX1100F1's Avatar
Default RE: Rear end replacement
Should be OK with that combo.
If you want to swap ratios then just have shop replace the ring and pinion set.
Old Aug 29, 2006 | 4:38 PM
funky_junk's Avatar
I think I'll be OK too. Most of the guys that are telling me this have chevy HD and cummins blah blahs with stroker this and that's. They are just used to hauling like there's nothing back there. I just think mountains will be a little painful.
Old Aug 29, 2006 | 5:24 PM
Black 5.3's Avatar
man you read my mind i just got mt ring and pinion in the mail today they are 4.56 richmond part# 69-0167-1 from summitracing.com i have the 4.10s on my other truck and they are nice but still didnt feel rite with overdrive tranny...this time im going to install 4.56 in my 2WD tahoe should pick up bit more low end..
ill let you know how it feels in couple days
Old Aug 29, 2006 | 5:30 PM
funky_junk's Avatar
ORIGINAL: Black 5.3
How much did that set you back? Oh, and how much do you think it will cost to install? I am just wondering what affects this will have to the warranty.
Old Aug 29, 2006 | 5:52 PM
Black 5.3's Avatar
here they are http://store.summitracing.com/partde...5&autoview=sku
install should be $400-500
about the warranty well thats the best part .. dont tell em bro
Old Aug 29, 2006 | 6:10 PM
funky_junk's Avatar
Thanks Guys. Now I guess I will see how it goes for a few weeks and then see if I need to make adjustments.
Old Aug 29, 2006 | 6:51 PM
adjmcloon's Avatar
I'd be interested to hear how this changed the bottom end your Tahoe. I've got an 07 and it's a tad weak off the line.
Old Aug 21, 2007 | 11:09 PM
calientecafe's Avatar
Did the 4.56's help with gas mileage?
Old Aug 22, 2007 | 1:07 PM
MCF34's Avatar
If anything, a 4.56 will HURT gas mileage....forgetting the debate about 'sweet zone' for 4 cylinder mode, the higher the gear ratio, the more acceleration and the worse the fuel consumption. At higher speed, the higher gear ratio will be turning a couple hundred more RPM thus getting worse gas mileage. In the city, no doubt higher ratio will mean worse gas mileage...Another thing to consider...some higher ring and pinion combos 'whine'.....
