Rear Hatch will not open when below freezing
Old Dec 25, 2022 | 8:17 AM
jstein1206's Avatar
Default Rear Hatch will not open when below freezing
Hi All,
I have a 2018 Suburban... it appears when temps drop below freezing, whether we've had prior precipitation or not, the hatch will not open. It will "unlock" and attempt to raise but will not go any further than a few inches. After temps rise above freezing (given a few hours after that), the hatch will open. Once I forced it up and heard cracking/splintering, but nothing is broken.
Could moisture be in the shocks? I don't believe it's the motor but I'm no expert. It does attempt to raise up. I have an appointment with the local Chevy dealership but they can't see me until mid-January. And I was hoping maybe it was something simple and I could fix it instead of paying thousands of dollars.
Thanks all!
Old Dec 25, 2022 | 9:40 AM
Cusser's Avatar
Originally Posted by jstein1206
I have a 2018 Suburban... it appears when temps drop below freezing, whether we've had prior precipitation or not, the hatch will not open. It will "unlock" and attempt to raise but will not go any further than a few inches. After temps rise above freezing (given a few hours after that), the hatch will open. !
When it only will "go up" a few inches - now, don't get dirty here - lift the hatch manually and see if the two outer lift supports will hold the hatch open. If the hatch drops, then at least one of the two outer lift supports is faulty, went through this last year on our 2011 Yukon.
The fix is to install a new pair of lift supports. Open the hatch use a 2x4 or similar to hold the hatch in the up position, and replace the two outer lift supports. Easy. I bought our pair of lift supports through Amazon, less expensive than getting at local parts stores. Note the the smaller lift supports for the glass-only part are way different !!!
Old Dec 25, 2022 | 9:48 AM
jstein1206's Avatar
Thanks for the quick reply! When forced open (only did it once, didn't want to break anything), the lifts did keep the hatch up and there was no give in them. I think i agree with you that it's the two lifts, but wants to verify before i replace them.
Old Dec 25, 2022 | 10:25 AM
repairman54's Avatar
If even one strut is weak the lift motor will shut down in its protection mode. Cold weather brings out the weakness in those struts.
Old Dec 26, 2022 | 7:30 AM
jstein1206's Avatar
Thanks all, looks like it's the struts, I've purchased a set and we'll see how it goes.
Old Dec 26, 2022 | 11:00 AM
Welcome to the forum. Hope the struts solve your problem.
SkookumB
Uplander
11
Nov 24, 2019 5:03 PM
Sherrif80
Feb 17, 2019 1:27 AM
Craig Goth
Oct 9, 2017 1:25 PM
VsZ71Hoe
Jul 5, 2011 11:34 AM
Seabass
Dec 28, 2008 2:48 PM
