Rear liftgate Fuse location
Old Aug 4, 2010 | 11:37 PM
MHarv's Avatar
Default Rear liftgate Fuse location
Does anyone know where the rear lift gate fuse is located on a 2005 Suburban? The rear latch will not lock with the rest of the doors anymore. I already checked the fuses under the dash and in the engine compartment. Any help would be greatly appreciated.
Old Aug 5, 2010 | 1:28 PM
15 Year Member
Welcome to the forum.
There are two fuse locations, one under the hood and the other at the end of the IP on the driver's side behind a cover.
Old Aug 5, 2010 | 3:12 PM
if you have check the fuses then you will probably need to pull the rear panel off and use a meter to see if the pulse is getting to the lock actuator.
i'd be my guess the actuator is bad or the connector has come loose...
Old Apr 16, 2025 | 9:27 PM
teinika1983@yahoo.com's Avatar
Default I've Got the same issue
Did you get it figured out and what was the problem?I already changed that And I cannot find a fuse
The bald one
Jul 18, 2024 3:09 AM
DukeSilver
May 23, 2024 1:51 PM
avray22
Aug 1, 2019 10:34 PM
Kim Hodge
Aug 11, 2017 8:18 PM
cezardob
Jan 3, 2009 3:38 PM
