Rear window fuse 08 burb
Old Jun 4, 2020 | 2:34 PM
stayathomedad's Avatar
Default Rear window fuse 08 burb
Both of my back windows won't go down or up by the door switch. They go from the driver switch but not at the door. The lock button on the drivers switch doesn't do anything, I tried both ways. Could both window switches be bad? Is there a fuse somewhere?
Thanks
Old Jun 4, 2020 | 3:21 PM
Cusser's Avatar
Not a fuse issue, as they operate from the driver's buttons.
Either bad switches at the doors, or possibly bad wires.
Old Jun 2, 2021 | 5:46 PM
2008 Chevy Suburban LS1500 5.3's Avatar
Exclamation 2008 Chevy Suburban LS1500 5.3
Thanks
Did you ever get this figured out?
Old Jun 3, 2021 | 6:32 AM
Yes I did. There is a wire in the loom that goes from the drivers door gam toward the inside fuse block that was broken.That wire must be in the entire window circuit.It's not a hard fix but there isn't a whole lot of space to do the repair since you have to work with the door open.
Hope this helps
Old Jun 3, 2021 | 7:15 AM
repairman54's Avatar
Hope this helps
Thanks for coming back with your fix, it helps others, thanks again.
Old Sep 26, 2022 | 9:19 AM
kingofbytes's Avatar
Hope this helps
Hi there! I'm running into this exact issue. Was the issue in the door frame or in the vehicle frame near the drivers door?
StarChyldd
May 25, 2017 2:57 PM
sling
Jun 25, 2015 5:09 PM
voodoo91870
Mar 17, 2011 11:38 AM
kylemason
Nov 21, 2010 10:11 AM
bn11th
Sonic (Aveo)
Oct 15, 2010 5:27 AM
