Rear windows
Old Mar 15, 2019 | 7:19 PM
David Carroll's Avatar
Default Rear windows
I have a 08 Tahoe ltz and the rear windows won’t roll down only from the master switch what can cause this
Old Mar 16, 2019 | 9:04 AM
Cusser's Avatar
You're new here, I'm trying to decipher your post. If your rear windows do not lower using the master switch but do lower/raise from the rear door switches, then sounds like a bad master switch.
Do the rear windows raise using the master switch?
Old Mar 16, 2019 | 10:30 AM
They roll up/down with the master switch but don’t roll up/down with the rear door switches
Old Mar 16, 2019 | 12:05 PM
Cusser's Avatar
Originally Posted by Cusser
You're new here, I'm trying to decipher your post. If your rear windows do not lower using the master switch but do lower/raise from the rear door switches, then sounds like a bad master switch. Do the rear windows raise using the master switch?
I was correct: I didn't understand your post, your wording was vague.
You need to determine whether positive voltage is getting to both rear window switches with the ignition in the "run" position. If so, and rear switches don't work, then switch(es) are bad. If not, maybe wire not connected at the master switch. A wiring diagram for 2008 would help you.
Old Mar 19, 2019 | 11:11 AM
Check to make sure the master switch panel lock out is not engaged for the rear windows. There is a button/switch on the master panel that you can use to lock out the back windows to keep your kids or pets from rolling down the windows.
Old Mar 19, 2019 | 2:14 PM
Cusser's Avatar
Good point; I drive our GMC so little I forget about modern safety stuff like that. Unfortunately, every time I try to look up anything in the owner's manual, it takes me from chapter to chapter.
