Reclining Bench Seat
Old Nov 14, 2013 | 8:41 PM
eodtek32's Avatar
Default Reclining Bench Seat
My 92 Suburban has the standard bench seat in the front. A while back I had a taller-type friend ride and as he tried to stretch out a bit the seat popped back about ten degrees to the rear. I would like to get the seat back close to the original near vertical position. How difficult might this be? This is my preference as I had the seat re-upholstered about three years ago.
My other option would be to find a decent bench seat at a local junkyard and try to swap out the coverings.
Does anyone have advise on adjusting my bench to its original position?
Thanks in advance.
Old Nov 14, 2013 | 8:45 PM
15 Year Member
Welcome to the forum.
Did he break something? If so, then probably have to weld it which means removing the upholstery in the area of the repair.
Not familiar w/ the bench but does it have a mechanism to allow reclining?
Old Nov 16, 2013 | 9:58 AM
eodtek32's Avatar
Thanks for the response.
Not sure if he 'broke' something or just 'stretched' something out. The seat has a fixed position and has no reclining capabilities.
If I sit in the back seat and press against the front seat with my knees my wife is unable to see anything move, but it does 'sit' a bit more vertical. I may have to remove or at least open up the upholstery to get a closer look.
Old Nov 16, 2013 | 10:24 AM
15 Year Member
It sounds like from your description, that he broke something.
parobellum
Jun 18, 2012 12:15 PM
IslandExpress
Nov 6, 2011 8:56 PM
Kevinh111
Mar 18, 2011 7:12 PM
srchn4noval
Apr 8, 2008 11:00 PM
rngadng
Jul 10, 2006 2:57 AM
