Reclining Bench Seat
Old Nov 14, 2013 | 8:41 PM
eodtek32's Avatar
Default Reclining Bench Seat
My 92 Suburban has the standard bench seat in the front. A while back I had a taller-type friend ride and as he tried to stretch out a bit the seat popped back about ten degrees to the rear. I would like to get the seat back close to the original near vertical position. How difficult might this be? This is my preference as I had the seat re-upholstered about three years ago.
My other option would be to find a decent bench seat at a local junkyard and try to swap out the coverings.
Does anyone have advise on adjusting my bench to its original position?
Thanks in advance.
Old Nov 14, 2013 | 8:45 PM
Welcome to the forum.
Did he break something? If so, then probably have to weld it which means removing the upholstery in the area of the repair.
Not familiar w/ the bench but does it have a mechanism to allow reclining?
Old Nov 16, 2013 | 9:58 AM
eodtek32's Avatar
Thanks for the response.
Not sure if he 'broke' something or just 'stretched' something out. The seat has a fixed position and has no reclining capabilities.
If I sit in the back seat and press against the front seat with my knees my wife is unable to see anything move, but it does 'sit' a bit more vertical. I may have to remove or at least open up the upholstery to get a closer look.
Old Nov 16, 2013 | 10:24 AM
It sounds like from your description, that he broke something.
parobellum
Jun 18, 2012 12:15 PM
IslandExpress
Nov 6, 2011 8:56 PM
Kevinh111
Mar 18, 2011 7:12 PM
srchn4noval
Apr 8, 2008 11:00 PM
rngadng
Jul 10, 2006 2:57 AM
