Remove front axles/Driveshaft?
Old Jun 26, 2015 | 10:07 PM
Deviat's Avatar
Default Remove front axles/Driveshaft?
Folks, I've got this clanking in the front end somewhere that is apparent as soon as i start driving. It is definitely in the front, I assumed it was probably the front hub bearings so I replaced those, then replaced the axles after the noise was still there. Either its the Carrier (probably those bearings) or the front drive shaft.
My question is, can I remove the front axles and driveshaft, essentially making it a 2WD rig for a month while I remove the front diff and rebuild it? I'd rather not have it grenade on me. I know I should be fine on the front axles, but will the front driveshaft cause a leak in the transfer case?
Thanks gents!
Old Jun 27, 2015 | 8:04 PM
the front driveshaft does not turn in 2wd so if the noise is present in 2wd it can't be the front d-shaft.
no you can't drive with the front axles removed or your wheel bearings will be destroyed. the axle and hub nut tension the bearings.
Old Jul 1, 2015 | 7:30 PM
Deviat's Avatar
Makes sense. Guess I will baby it for the next month.
Thanks for replying!
jmansouri
Apr 27, 2014 8:32 PM
1Ton-K1500
Jun 13, 2011 3:49 PM
ger87410
Nov 14, 2008 10:44 AM
bigmmarc66
Feb 25, 2008 12:58 PM
huskersdomn8
Feb 22, 2007 11:23 AM
