Last edit by: IB Advertising
Browse all: Steering and Suspension
- Chevrolet Silverado 1999-2006 GMT800 How to Replace Front Axle CV Joint
Replacing front driver's Side axle bearing
I am about to replace the driver's side front outer axle bearing on a 98 Tahoe 4x4. I noticed that there is no axle tube on that side. Could someone tell me if I have to crack the differential open to get to the outer bearing? I was not sure how the axle stayed in the differential. I have worked on plenty of front differentials on the older Chevys, but have yet to work on this style. The older ones had c-clips or pins. If I do have to go into the differential, would it be better to remove it from the truck before disassembling it? Any info would be greatly appreciated.
I read in a Haynes manual that the drivers side front axle comes out of the differential by using a pry bar and a rubber mallet (basically hammer it out). Does that mean there is no retaining mechanism that needs to be removed before pulling the axle? I would really like to know what I am going to get into before I start disassembly. Thanks.
I see the ring on the end of the axle shaft in the exploded view. Will that ring clear the axle bearing? Basically, can I replace the axle bearing without pulling the differential?
Ride of the Month
May 2009
Ride of the Month
May 2009
The ring clip will clear the bearing, you may want to use a slide hammer to remove te axle. the bearing in the diff housing is held in by a screw in adjuster. Are you sure that bearing is bad?
I started getting a strange vibration in the right front when decelerating. Over time, the vibration started getting worse. So, I jacked up the front and checked the hub. It was in pretty good shape (no play). I then checked where the cv joint attaches to the axle flange. There is some pretty noticeable play with the axle (it moves up and down pretty good). I figured that the bearing should keep the axle shaft pretty tight. The passenger side axle has almost no play. So, I am pretty sure that the bearing is going out. Think my assumption is correct?
As far as the screw in adjuster, I see where the 3/4 ton has one, but did not see one on the 1/2 exploded view. I guess I can pull the cv shaft, then slide hammer the axle out and see what it looks like.
Thanks for the info Mud! I am going to tackle it next weekend (we just got 8 inches of snow and ice here, so not a real good time to work on it). I will post a reply on what I found.
Dan Cina
March 12th, 2013 1:00 PM
DC_443
December 2nd, 2011 3:10 PM
